Narcis_AMD
- Apr 30, 2017
Hello everyone,this is my first post here,and also my first OC.
I have 1115 Core Clock,1250 Memory Clock,stock Vcore and the temperature while gaming (Mass Effect Andromeda in this case) 68-75 Celsius Degrees. Stock Cooling(no aftermarket for gpu) and it stays in 100% load ofc while gaming.
Should I keep the powerlimit up to 50%? Now I am on 1115 core clock and memory 1250(I heard that overclocking memory clock is not very important in my case because it has 512bit)
and (this morning I decided to undervolt and overclock step by step) for now,I have no problems.
Oh,and as for PSU I own inWin Commander 850W so,power is not a problem for me.
As an edit,I want to add the fact that for undervolt i succeded -50mV(stock clocks),now I am on stock voltage with 1115 Core clock and 1250 memory clock and the same temperature as above. I gained 8 FPS in Mass Effect Andromeda(maybe less or maybe even more in a different environment) I just want to know the MAXIMUM SAFE VOLTAGE and power limit for overclocking my r9 290 because I would like to go higher. Right now,VRM1 temp 46 Degrees Celsius and VRM2 temp 56 Degrees Celsius in full load. Is it worth the extra 10mhz going from -31 mV to stock voltage(from 1100mhz core clock and 1250 memory) ? I am waiting for answers.
