I should add: it is quieter than the stock CM212 Evo fan. I never could hear it over my intake fans (Noctura 140mm ippc-3000s throttle waaaay down cause they aren't pushing a rad...).The 1700? It's quiet and maybe good for 3.7ghz on all cores. That's if you can hit that clock speed on stock voltage.
That's the old wraith cooler for FX and A10.http://www.relaxedtech.com/reviews/amd/wraith-cooler/2
looks like its fairly good for a stock cooler.
*Double posted
In my case I didn't find any difference between the NH-D15 and ambient water cooling. The CPU wasn't that hot to begin with and it hits the voltage limit before the cooling limit. That was my experience with 3 CPUs
OP was talking about the milled block of aluminum that is called the wraith spire (factory cooler for the Ryzen 7 1700… with purdy LED lights!).
It isn't great, but works if you are waiting on a cooling bracket. I managed to hit 3.7ghz on mine, others topped out ~3.6ghz.
No problem. The wraith spire is interesting, but not as good as the old wraith.My bad didnt realize they had an updated one
I find it interesting that purely from a gamer's perspective, the "value" tables have now been reversed. i5/i7 Kaby Lake is now the best bang for the buck. Of course, we shall have to see if that remains true when AMD releases the lower core count Ryzens (supposedly sometime this month).
Considering the clock speeds from Ryzen so far I don't see them doing much damage to my Skylake for gaming, let alone a 7700k. They may reclaim their "value" title but I don't think they'll beat the 'Lakes.
1440p is where games start becoming GPU bound and not CPU bound. To me, there is a point where the CPU isn't important in 1080p. That's my crappy monitor's refresh rate [emoji14]Yes, but my display is 1080p. My 1070 plays my games at well over 100 fps, so the extra performance from my CPU is useful over a much broader spectrum than a GTX 1080 would be. That logic would probably be sound up to at least 1440p, as well.
Stock cooler doesn't mean max OC on air. The best I think you can get from it is 3.7ghz and I only hit that cause I can run stock voltage to get there. My 212 has alot more temperature headroom, but I don't want to fight unstable bios to push it more. Waiting to buy my water block and hopefully will have a more stable bios by then. Things just seem to act funny, plus randomly when recovering from a crash my 'stable' ram decides it's randomly not stable. Everything works great as it is set right now, so gonna wait for a bit @ 3.7ghz. the 212 Evo keeps load temps down to 60C which is nice and cool.Yeah, the Ryzen is definitely no slouch. Back OT, I like the cooling situation that seems to be the norm for the 17xx R7s. Stock coolers allowing for the max OC the chip is capable of is great. I'm thinking the potential for getting more people to OC if they don't have to jump through the cooling hoops they did with FX or Kaby Lake. I may start saving for another build just so I can play with one.
In the discussion thread? Johan was talking about big air. The wraith spire is kinda crappy, yet purdy with it's RGB ring. It still works enough to squeeze the 1700 a bit.I was basing it on what Johan45 posted yesterday.
