- Oct 22, 2008
- Boise, ID
So I am setting up a WC system for the first time in 6 years (had an old WC system,) and have been reading up on the famous "two-drops of PT Nuke and your good" theory. I put the PTNuke in my shopping cart at Petra's for the tune of $2.50, but then they wanted $12.00 shippng.... So I headed off to Walmart to see if they had some sort of pool cleaning solution that contained Copper Sulphate. I found some stuff that had 11% concentration but was $30.00 for a bottle that would last me forever (PT Nuke is 4%.) I saw nearby a bottle that claimed to be close to the same effectiveness, but not as good. Its "HTH Spa non-foaming algaecide" it was only $4.98 and it contains "n-alkyl dimethyl benzyl ammonium chlorides - 9.96%" and "n-Diakyl Methyl benzyl ammonium chlorides .04%" as the active ingredients. It says on the bottle "Prevents and kills all types of algae" also "Do not mix with other water treatment chemicals." And it comes in a 14 ounce bottle, but says 1 ounce will treat 390 gallons... so I have a life supply... literally.
So now my questions:
1. Do you think "do not mix with other chemicals" means anti-freeze too? (I want anti-freeze for the anti corrosion (let me know if there is a better way to prevent corrosion))
2. Any idea if these chemicals will hurt my Swiftech 655, 86 chevette HC, or my SCW-REV.A waterblock?
3. Do you think the ammonium chloride will be strong enough to keep the crawlies out?
Thank you!
Tubesock,
P.S. Never was a Biology major
Thank you!
Tubesock,
