Hi, new to the forum and have been doing research about water cooling for a few weeks now, looking to finally begin to finalise my plan for a first time WC set up. Originally I was planning to go CLC, but i decided against it.
System spec:
i5 2500k @ 4.0GHZ 1.25V Aircooled (Planning to take it upto at least 4.5 with WC)
Asrock P67 Extreme 4 Motherboard
8GB of G.Skill Ripjaw DDR 3
512GB Samsung 840 Pro SSD
750W Silverstone strider plus
PARTS
This is the part where I would love some opinion on and I have questions about.
CPU Block: Koolance 380i or EK supremacy Acetal + Copper base (Deciding)
RAD: Alphacool Nexxxos Monsta 360
RAD Fan: 3 x alpenfohn wing boost 120MM or Scythe GT 1850 RPM (Deciding)
RES: EK D5 X-RES 140 Black Acetal (with D5 pump top)
Pump: XSPC D5 Vario
Tubing: XSPC white 1/2" ID 3/4" OD
Fittings:Bitspower compression fittings
Coolant / Additive:Distilled water + additive?? (Need Opinion)
Loop plan:
Planning on a loop of Res -> Pump -> Rad -> CPU -> Res
Questions Time!
1. How are the part choices? Any other recommendation? Slightly worried about the nickel plating of the koolance 380i and the plating of compression fittings flaking off and mixed metals (brass from fittings, nickel from plating on the cpu block and copper rad)causing any form of corrosion. Should I just stick to an acetal + copper EK supremacy all together to avoid the mixed metals?
2. What additive should i use with this set up? I read that Koolance strongly advise against silver with their nickel plated 380i block, so that's out of the question... Maybe Liquid Utopia? PT nuke? IandH Deadwater? What's something that act both as a biocide and anti corrosion additive? (If i go with EK supremacy, Might just use silver coil + anti corrosive??)
3. For the EK Res + D5 pump top, since (I'm guessing) the res auto feeds into the pump top, so the two combined I only require 1 In fitting and 1 out fitting?
Thanks a lot for reading and really looking forward to reading all of the opinions & advice
System spec:
PARTS
Pump: XSPC D5 Vario
Loop plan:
Questions Time!
