- Dec 27, 2008
If anyone still cares, I stumbled upon what seems to me to be the easiest fix yet for the broken Windows 7 update when installing from scratch.
1. Install Windows 7 from media as usual.
2. Choose "I'll Decide Later" when the installation process presents you with choices for installing updates.
3. Immediately after the installation is complete, go to Control Panel>Windows Update and click on the update settings link. Configure settings to "Check for but let me decide what to download and install." Do not leave it on Automatic.
(Skip steps 4 and 5 if your installation media comes with SP1 already.)
4. Allow Windows Update to search for updates. It will find several. Install them and reboot.
5. Tell Windows Update to check for more updates after rebooting. It should find SP1 to download and install. Do that and reboot to finish the SP1 installation.
6. Download the IE 11 stand alone installer and install IE 11. This process will also install necessary dependencies.
7. Reboot
8. Download and KB3102810 but do not install it just yet.
9. Reboot
10. Install KB3102810.
11. Reboot
12. Now run the Windows Update. It should find and install new updates without a problem from this point.
I stumbled upon this solution here: http://www.repairwin.com/windows-update-8007000e-error-solved/ after not having success with WSUS Update Offline which had worked for me in the past. The website I just referenced also suggested rebuilding the SoftwareDistribution folder but this proved to be unnecessary in my experience. The above steps worked for me on two different Windows 7 versions (Ultra 64-bit and Home 32-bit). If anyone has the time to try this method out it would be helpful for confirmation.
7. Reboot
9. Reboot
11. Reboot
