I cant seem to hide my wires to where my rig looks clean, its all scattered.
Would you guys out there mind putting some pictures of your rig and give me some tips? Ill take pictures of mine when my red led fans get here.
yeah i tried to shove as much wiring as I could into that space they give you behind the hdd racks. One of these days I'll drill myself some cable management holes, though I wish Antec would just make a 300 v2 with holes and a window lol.
Yeah I know what you mean, the little compartment behind the hdd cages is fine for lower wattage psus and not to much wires, but for more extreme it wouldnt fit. Antec430W isnt sleeved either so the power cords black yellow and red wires make the cable managing look like a mess.
Cut a hole infront of your PSU. One next to and kind of under mobo next to 8 pin conector. Another hole next to 24 pin. Now run all wires under tray u can use the 8 pin hole to run the fan molex conectors ( u might need an extension for a the 8 pin). Be careful not to leave charp edges.
Doh, sorry, change the ftp to http. I'll edit my post. I also didn't post images because they will be deleted in the future and will just show nothing...basically it wouldn't make sense
