I have a few questions for 900 owners.
1) Does anyone have a good idea for giving the case some dust filtering?
2) I've heard the Thermalright 120 is too big to allow it to coexist with the side panel mount. True?
If so, I was thinking a solution might be the mount the fan outside the case, either by taping it or drilling screw mounts, and snaking a molex connector through the water cooling port in the back. Any problem with this idea? Does the side fan even have a major benefit or is it better to just leave it open as a vent?
3) Is there enough clearance with an 8800 GT to use the fan connector at the back of the hard drive bay? Can you still use the middle slot for a hard drive while that mount is still attached?
4) What's the best fan configuration? I'm guessing the rear and top fans exhaust, everything else (including the side mount) blowing in?
5) I don't know which MB I'm going to get yet, but am I likely to face any problems reaching power connectors and such with a corsair hx520 PSU?
6) Any other general tips when building a system into that case?
Thanks.
Thanks.
