- May 9, 2011
- Alberta, Canada
I purchased a Zalman ZM-MFC3 fan controller without doing prior research (I know, I know. It was an impulse buy) and found out that it's not compatible with the case fans in my Antec 902 since they have no rpm sensor wires. So as I've been looking to replace my stock fans anyway, I figured I'd get three 120mm Silverstone Air Penetrators and a 200mm Cooler Master Megaflow to swap out. The APs went in without a problem, yet when it came to installing the 200mm fan, I soon realized that the mounting holes aren't compatible
So, my question is, what are my options for mounting this fan in my case? I'd rather avoid zip ties as I prefer to keep it looking somewhat professional.
Also, there was a thread I came upon that had instructions to add a sensor wire to the 120mm stock fans by peeling back the sticker and soldering a wire to a specific spot on the back. I tried peeling back the sticker on the 200mm fan, but the plastic is solid with no way to access the circuit board. Does anyone know of a way to add an rpm sensor wire to the 200mm Antec Big Boy fan?
Thanks in advance.
Thanks in advance.
