- Aug 15, 2004
http://www.antec-inc.com/us/productDetails.php?ProdID=80632#
This is the case I have and I was wondering about ways to cool it better, currently using stock fans and whatnot. I won't quote what I have running in it currently because temps are fine, but I'm wanting to start improving cooling for a future upgrade.
I'm wanting to use 120mm fans, prolly
http://www.frozencpu.com/cgi-bin/frozencpu/fan-18.html
Also, being I am only using one hard drive and one cdrom, nothing else in the bays I was thinking of getting an adapter for the harddrive so it will go in the 5.25 bay and then remove the removable 3.5 bay for added airflow.
Not sure as to what powersupply I am going to end up with yet.
Most likely going to be getting an AMD FX-55, an SLI motherboard, and 2 top of the line nvidia cards.
74gig raptor, and been thinking about
http://www.newegg.com/app/ViewProductDesc.asp?description=27-131-328&depa=0
for the CDROM
For a heatsink I want to get the XP-120 if it will fit the motherboard I pick, and using another one of those fans I listed above on it.
Any suggestions?
Currently using a dual fan cooler in one of the 5.25 slots but would rather replace that w/ a blowhole and another 120mm
I've never done any modding before or anything of the sort so plz give me an explination along w/ your solution if there's any doubt that I might not understand what you are talking about.
for the CDROM
Any suggestions?
