after a reboot I see that my temps are higher than it was in mb5, now it's @ 215*12 41idle... Iam going to prime now let see of it can handle 2.59 @ 1.825
you know that nf2 chipset has problems adjusting memory:cpu ratio right? so if you are not setting it to 1:1, you should set it back to it. Did you try modded bios??? there are literally over hundreds of performance bios for NF7, try different bios and see which one would your board like.
