- Jan 9, 2005
I just picked up an Antec p182 case and had the intentions of performing some type of Mod that involves cutting some sort of window, or additional fan hole in the side. However, the material doesn't feel like normal aluminum and has this raised pattern on the inside of the wall. Therefore, I was hoping someone has done this before and can tell me any tricks needed or if a simple dremel will be sufficent to cut through it. I obvisouly would be looking to cut the cleanest edges possible so other tool recommendations would be appreciated.
