- Apr 1, 2004
- Vancouver Canada
I live in a student housing complex at university, that is pretty much the same as a condo. It's a 3 story wood framed building, built on the ultra cheap (leaky condo all the way). An 802.11g wireless network was installed through the place and this is what we are sudposed to use for internet. The problem is that they are cheap and didn't install enough equipment to get a good signal everywhere.
The signal on my linksys pci card ranged from 1-2 bars in good weather, and 1-disconnected when it rained, which is 90% of the time here in the winter. The problem seemed to be that there was almost no signal where my computer was, and I couldn't move it. To to fix this, I took a ~6' piece of coaxial cable, connected it to the antenna that is sudposed to go on the card (this involved a lot of electrical tape) and then soldered the coax to the pins sticking though the pcb of the card. With the antenna relocated, my signal now ranges from 4-5 bars
What I want to know is, am I going to kill my card or something? I'm not all that familiar with wireless networking equipment. I can't see anything wrong with this extention cable, but I really don't know.
-edit-
OK, I was testing it out and noticed something pretty strange. When there is pretty much no internet traffic (like mesenger only) the signal is at 4-5 bars, but when I load the connection, the signal drops way down to 1-2 bars. The connection stays connected at full speed, and everything seems to work fine, but whenever there is any traffic the signal drops way down.
On Cnet's bandwidth test I get a speed of ~3350 kbps, and everything is working nicely, I'm just a little worried about my signal droping so much, like the card can't handle the resistance of the cable or something.
-edit-
