http://www.inet.se/produkt/5322290/arctic-cooling-accelero-mono-plus
I just got this home ^
I had to change my GPU fan since my old one was very loud.
I'm not very used with this, but I'll try to explain as good as i can.
My computer:
Acer Predator G3610
Intel Core i7 -3770 CPU @ 3.40 ghz
12 gig ram 64b operatining system
Graphic Card: Nvidia Geforce GTX 560 TI
My case is pretty small so i really have to think strageticly when i place new fans.
Anyways! I was having some problems with my GPU temp, since it was rising to 80+C with my old ****ty (the one that came with the card) When playing (for example) world of warcraft
The old gpu-fan was screwed uder the graphiccard like any other fan, connected to the graphic card
OK, so the problem Is that when Put this new fan in (see link on top)
I connected it to my graphic card (4 thingy contact) and the strangest thing happend, It barely moved, my friend had to blow on it and it started to rotate alittle, then when i started wow it went alittle faster
Ok. So that didnt work, we checked my power supply, and there was no chanse that I was using more than i was dishing out
On the chord that followed with the fan (to connect to the graphic card)
There was 1 4pin and 1 3pin .. I connected the 4pin when this happend
Then after some playing around, we used a chord that followed with the fan.
You kinda plugged in the 4pin or 3pin into a 9v or 12v chord, and then later u could hook it up to your power supply
I connected my 4pin contact (from the gpu fan) into the PS and the fan started rotating fast when I started the computer, and the gpu heat was on like 30C idle, NICE i thought?
In this state the computer box was open since we were trying it out,
when i took it home i closed it and put it back on the floor, now when I started the comp, it went up to 55-60 idle, and 70-75 during gameplay like it almost was before
I downloaded MSI Afterburner or whats it called, and I tried changing the fanspeed that was set at 22% at the current state, but I didnt notice any difference, the heat didnt go down and nothing sounded louder, and I checked the "RPM" and it detected my rpm as 0
So What should i do?
Is there a way to configure a fan (gpu fan) thats connected to my powersupply, And why would it run so slow when i connected it into my graphic card? I mean, I got this newly freshly picked up today and I really dont know what to do :-(
So If anyone could share some light over this i would be reallllllllllly thankfull
Thanks in advance
My computer:
Acer Predator G3610
Thanks in advance
