Hello.
i just wanted to check if my temps are good.
I have a thermaltake shark case .Changed the front fan and the back with coolemaster jetflo(ohoooo now this is awsome cmf).And the preinstalled fans i put one on the low honeycomb panel as intake ,and remove the the 5" bay covers and installed the other one as exhaust.Now at room temp of 28 degrees celcius i see system temp:34 degrees idle and 17-18 degrees of cpu. At load i see 40 degrees of system and another 40 of cpu.Are these temps good enought for my warm Greece climate?
Thanks.
Thanks.
