- Jun 10, 2012
Here are my temps under load
CPU:35-45
Case:23-35
GPU:50-70
Are these okay???
CPU:35-45
Case:23-35
GPU:50-70
Are these okay???
Load = Gaming, Folding or Prime?Here are my temps under load
I am using it for gaming and I was just curious what temp I should be concerned about for the CPu and Case!!
Run prime blend test for an hour and see what the temps are like then. Substract 10°C from that value and you have the temperature you'll ever reach in real world application.I am using it for gaming
Case seems fine, too. As for the GPU, on air it is okay, assuming 70°C is at full load. For a liquid cooled GPU I'd expect some lower temps, but I never owned a liquid cooled GPU, so what do I knowwhat temp I should be concerned about for the CPu and Case!!
thenMy GPU is on air and 70 C is on hardcore gaming.
Indeed. Those temps are nominal.
I'm right about something for once...my loop is almost done 2 more pipes to lay!!
huh? I'am lost. Wrong thread.
