- Thread Starter
- #21
I have small cheap wired remote sensor digital thermometers to monitor case temp when building and testing. Auto supply store often have them, cheap indoor/outdoor with wired remote, terrarium wired remote. I usually monitor the air into cooler and/or GPU If you have a exhaust vent in middle top of case just setting a thermometer on it will give you an idea of the air temp your CPU is drawing in.
Stock cooler is the answer to me... temps look fine for that... perhaps a little warm, but..
Not sure I understand what that is asking.Is it because it doesn't have enough power to generate heat?
Good tip I know what temp sensor you're talking about. It feels really cool in the case so I think my problem is with the paste or just the fact that I'm using a stock cooler. Plus my case has 5 120mm fans so I can't imagine that it would be getting too hot in there.
If our stock cooler is one of the flat downflow kind and you can turn the fan over to pull air out of it instead of blowing into it that might lower your temps a bunch. I've ran tests on open bench with these downflows and had 8c difference with fan pulling instead of pushing.
If you want it explained please ask.
But if the air blowing down curls back up as it bounces off the RAM, GPU I/O casings, etc and gets sucked back into cooler by the fan. So the air is already hot going into the cooler.That depends on the cooler... some heatsinks will actually perform WORSE if you flip flop fan direction, especially the ones that blow down in to the heatsink and CPU... Try it and see, of course.
Think about it, the air on the front of the fan (direction it blows) is more powerful than what is coming in and is slightly more 'focused'.
