Before, I had a gigabyte 970A-UD3P and it would change my V8 GTS's fan speed accordingly depending on the cpu's temperature, just like any other normal mobo. The mobo ended up getting damaged and I replaced it with an ASRock 990FX fatality killer and I also kept the V8 GTS. I thought it would be an all around better board but the annoying part is that in the BIOS, it instead has Level 1-9 fan speeds and it doesn't idle/ramp up automatically based on the current temps. I don't know if it's possible with this board, or if mines just defective, but it's just plain annoying having the fan constantly be at 1200rpm for both idling on the desktop, and playing something like skyrim on ultra.
The reason I'm trying to figure out if this is normal or not is because I want to overclock my FX-6300 but at the same time I don't want my fans to only spin at 1200rpm with an overclock, but if I do make the fan speed higher to accomodate for the overclock, that means having an even louder fan speed for minimal things like idling at the desktop.
So my question is, is this normal for this type of asrock board? Or is there a way to make the fans speed change just like my gigabyte one did?
