I have an ASRock X99 motherboard with both PLED (2 pin connector) and PLED1(3 pin connector 2+/1-). I also have two momentary switches each with an LED (two wires). One switch I will use as a power switch and use the pins on the system header for power/LED. The other switch I want to use as a reset switch. I will attach the power wires to the reset connectors on the system header but the system header does not have reset LEDs connectors. Could I use the one of + connectors on the PLED1 and the - connector on the PLED1 to light my reset switch LED? Much appreciated.
Steve
Steve
