- Oct 17, 2011
I just can't deal with this anymore. I have read and tried just about everything to alleviate this issue but it keeps popping up. I have had runs of 14 hours and 6 hours with no issues but now it is reboting virtually everytime I get into windows 7.
Here is what I have done so far:
Disabled IGP.
Updated all drivers
Change vcore voltage to 1.19 fixed
Change vcore voltage to +.07 offset
Use xmp profile 1 for ram
Set all bios settings to default
Ran windows mem diagnostic and mem test with no errors
Raised and lowered mem voltage from the standrard 1.529 volts
clear cmos
Boot into safe mode
Unplugged all usb cables
I probably have done some more things that I am forgetting about...basically every suggestion I found in this and other forums, I have tried and it hasn't solved the problem.
What happens is you will be doing something in windows and all of a sudden the screen goes black and a few seconds later the computer restarts. Sometimes it gets stuck at the splash screen and restarts 2 or 3 times before booting into windows. No event log from windows, no BSOD, no warning. Sometimes it happens while watching something, sometimes while surfing the net, sometimes while not doing anything. CPU is not overheating, temps never above 44c, GPU not overheating, temps not above 50, I am at a total loss as to how to fix this problem. Also at first bios splash screen was showing A2 in lower right corner but now it shows A3, not sure what that means if anything, since it doesn't affect the booting up usually.
Just built this cmp and have been running it about 5 days now. I7-2600k cpu, 12 gb Gskill Ripjawz DDR3 1600 RAM, Sapphire Radeon 6850 HD video card, Windows 7 ultimate, asrock extreme 3 gen 3 mobo, Enermax 500W PSU...
In hindsight I should have stuck with Gigabyte, my previous mobo in my last rig...never had 1 problem out of that board in over 5 years. Imho, there is something seriously wrong with these mobo's to keep having the same issues over and over. I will update bios to 1.10 as soon as I can get in and it stops rebooting but it doesn't appear like it will do much, since the big thing is supposedly improved mouse function. Not a happy camper right now...have never had this many issues with a mobo and I have built many, many computers in my day...
Here is the axtu screen showing PSU should not be the problem as voltages all look good and are stable...
(Will post when I get home...all voltages are stable and look normal..no bouncing around or anything like that...)
Here is info from Event Viewer saying computer unexpectedly shut down:
- System
- Provider
[ Name] EventLog
- EventID 6008
[ Qualifiers] 32768
Level 2
Task 0
Keywords 0x80000000000000
- TimeCreated
[ SystemTime] 2011-10-17T04:14:24.000000000Z
EventRecordID 7320
Channel System
Computer MNasty-PC
Security
- EventData
12:12:08 AM
10/17/2011
2109
DB070A000100110000000C0008004302DB070A000100110004000C0008004302600900003C000000010000006009000000000000B00400000100000000000000
Binary data:
In Words
0000: 000A07DB 00110001 000C0000 02430008
0008: 000A07DB 00110001 000C0004 02430008
0010: 00000960 0000003C 00000001 00000960
0018: 00000000 000004B0 00000001 00000000
In Bytes
0000: DB 07 0A 00 01 00 11 00 Û.......
0008: 00 00 0C 00 08 00 43 02 ......C.
0010: DB 07 0A 00 01 00 11 00 Û.......
0018: 04 00 0C 00 08 00 43 02 ......C.
0020: 60 09 00 00 3C 00 00 00 `...<...
0028: 01 00 00 00 60 09 00 00 ....`...
0030: 00 00 00 00 B0 04 00 00 ....°...
0038: 01 00 00 00 00 00 00 00 ........
and here is another one saying system has rebooted without cleanly shutting down first:
- System
- Provider
[ Name] Microsoft-Windows-Kernel-Power
[ Guid] {331C3B3A-2005-44C2-AC5E-77220C37D6B4}
EventID 41
Version 2
Level 1
Task 63
Opcode 0
Keywords 0x8000000000000002
- TimeCreated
[ SystemTime] 2011-10-17T01:15:22.605621300Z
EventRecordID 6161
Correlation
- Execution
[ ProcessID] 4
[ ThreadID] 8
Channel System
Computer MNasty-PC
- Security
[ UserID] S-1-5-18
- EventData
BugcheckCode 0
BugcheckParameter1 0x0
BugcheckParameter2 0x0
BugcheckParameter3 0x0
BugcheckParameter4 0x0
SleepInProgress false
PowerButtonTimestamp 0
Disabled IGP.
Updated all drivers
clear cmos
Boot into safe mode
- System
- Provider
[ Name] EventLog
- EventID 6008
[ Qualifiers] 32768
Level 2
Task 0
- TimeCreated
EventRecordID 7320
Channel System
Computer MNasty-PC
Security
- EventData
12:12:08 AM
10/17/2011
2109
Binary data:
In Words
In Bytes
- System
- Provider
EventID 41
Version 2
Level 1
Task 63
Opcode 0
- TimeCreated
EventRecordID 6161
Correlation
- Execution
[ ProcessID] 4
[ ThreadID] 8
Channel System
Computer MNasty-PC
- Security
[ UserID] S-1-5-18
- EventData
BugcheckCode 0
