I'm hoping to!
Until now the AK_v8 app wouldn't let AstroPulse units run (unless you modified the *.xml file). But an optimizer for AstroPulse is out now and includes instructions for adding AstroPulse into the AK_v8 *.xml file.
Crunchin', crunchin' crunchin' ...
Do you have a link for the astropulse optimizer?
Sorry - thought I linked it: http://setiathome.berkeley.edu/forum_thread.php?id=49749Do you have a link for the astropulse optimizer?
The AstroPulse optimizer doesn't replace the AK_v8 app, it just adds an AP app to it, so you might try it on one system just to see. You still use your AK_v8 SSSE3 apps for "normal" WU's you just modify the *.xml to reflect your normal AK_v8 app (the AP *.xml has NO calls for a normal WU app - it's meant as an add-on). From what I understand the AstroPulse optimizer cuts compute times WAY down - some people have reported a 100% gain (half the time to compute AstroPulse) with just SSE3.I think I'll hold off until they put out optimized apps that have SSSE3 optimizations minimum and hopefully with SSE4.1 for my QX. Everything I am running has SSSE3 optimizations on them.
I know that Mictlans workpc has completed one at 84 hours - and got granted 759 CS...
I´m not sure if that box is optimized tough...
Just a thought ...
