- May 8, 2003
Asus A8N-SLI Premium 4gb of ram problem
I've been having issues lately with not enough ram so I decided to upgrade from 2gb to 4gb but i've been having nothing but problems, i'm running Windows 7 64bit, bios 1009, all 4 sticks are OCZ platium, OCZ4002048ELDCPE-K, I set my memory voltage to 2.8v, 2-3-3-6 2T timings but regardless it won't work right, it will boot and seem to work fine, but next boot it will blue-screen, go thru the auto repair, say it can fix it, then next boot will be fine, then it does it again, I read online people saying they were running the exact same memory with 4gb and the same bios fine so the combo should be ok, but it's not, anyone have any ideas on how to get it to work properly?
Thanks
edit: I guess I should also note I disabled my overclocks as well so the system is not overclocked to what my sig says, it's running stock speeds.
Thanks
