Hello,when I try erasing my hard drive via window washer,it just stay on the screen where it says calculating drive geometry. I beliave it's a problem with the MB,I put the drive in a different PC and it erases no problem,what could be the problem?
Are the chipset drivers loaded on the PC which it doesn't work on? It sounds like the system having the problem cannot read the details of the drive - have you had any problems with the drive? Could be going bad, according to what I could find on webroot's support site.
My first thought was the drive may have errors on it, but that can't be the case if it works in a different system. If the drive is dieing, maybe you got lucky on the other system?
I don't think either of those are very good answers, someone else may have better.
