I recently bought an Asus A8V Deluxe and an Athlon 64 3000+ cpu. I have everything installed and booting up properly, the BIOS says the cpu is 1800mhz, but CPUz shows core speed as 901mhz and HTT as 100mhz. However, ClockGen shows my HTT as 200mhz and allows me to bump it up to 400mhz. If I set it to 400mhz in ClockGen, then cpu-z shows the HTT as 200mhz and core speed as 1800mhz. There is a dramatic increase in speed when I do this and no stability problems. I currently have Cool-n-Quiet disabled, but I've tried with it enabled as well. No matter what I do in the bios or anywhere, it always boots up at half-speed in windows and memtest86. I am running BIOS version 1009.007. I tried the beta 1010 but it made no difference.
Also, Windows will not detect the onboard sound device, nor does the bootup device list show it. It is enabled in the bios and I have installed the drivers from Asus, but still no devices are being detected (other than Legacy Audio Drivers, etc). I tried installing the device/drivers manually but it says device startup failed.
Any clues? It's driving me nuts.
