Asus Croshair V Formula Z EZ plug.
jarokamaro007
Hey.just want to ask if i realy need to use that plug if i run 2x Matrix Platinum GPU's??i seen on some forums some lads said i dont have to use this plug...i dont want to have that cable going all the way thru my build :(
Manual says that to connect EZ_PLUG to ensure sufficient power suply when you instal multiple GPU's...but some lads said i dont need to plug it ...i dont know :(
use it anyway, multi gpu is what it's there for, I even used it when I ran hd7770's in crossfire.
Some boards REQUIRE it in that multi gpus will not work without it. Others it's recommended. You don't lost a model gpu, just matrix platinum -there are several, and do not have a signature so I am not sure what cards you have.
Either way, I'd run with it.
