- Jan 27, 2007
- Yuma, Arizona
I bought this motherboard about a year ago. It worked fine for the first few months and then all of a sudden. It wouldn't post. I read a few things and I replaced the CMOS battery, this remedied it...for a little while. Now it seems like I replace CMOS batteries every month or so AND every now and again, it'll give me the error "insert system disk and press enter" upon a hot boot and then a few cycles later it'll boot like nothing happened. Very strange to me. I'm done messing with it unless you guys can part some knowledge on a way to fix this problem. All my components are just over a year old and the machine runs like a dream when its not having these dumb problems.
If I can't get any information on how to fix this I've decided to simply purchase a new board, but I'm at a loss at what to buy. Current system specs are listed in my signature, but I've been looking at purchasing the motherboard listed below. What do you think? Also, I'm counting on there being issues of swapping out the motherboards what can I expect to run into if I keep all my current hardware; which is what I aim to do? Would you be able to tell me of any compatibility issues with my current hardware going onto this motherboard The main purpose of my rig is gaming.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131361
Thanks!
Thanks!
