- Jan 12, 2015
Hey Guys
I have put this in here to see if anyone else has seen this problem or have have it happen to them.
I'm competing in the Country Cup under the GPUPI section as I only have AMD hardware. I have already lost 1 CHVF-Z, FX 8370, and a FX 8320 during the competition. I had to use my backup CHVF-Z that I had setup for sub-zero benching with the FX 8350. Here is my problem :
I had setup my computer for a World Record run in GPUPI on Sunday Nov 22 powered by a Evga 1300w Supernova G2. I came in 8th under GPUPI 1B using 3 R9 290x's and a R9 290 using only H2O. On Monday Nov 23, I had turned my computer on for checking e-mails and surfing the web. The computer had been on for about 5-7 minutes when I received a warning from AI Suit. The WARNING stated " SB 0.0000v " and then the computer rebooted but failed to make it to the POST. The motherboard now will only light the Start & Reset buttons and power USB drives. The board will not power on by the Start button, Nor the Direct Key, Nor the Power on pins. The reset the bios switch gives a quick blink but does not stay lit. I have already contacted Evga to see if it could be a power supply problem. I have been informed by Evga that this is not a power supply problem.
The computer will not power up to even give error codes or lights to help trouble shoot the problem. The motherboard has a broken memory clip but this has not caused a problem before.
I did not have the video cards OCed ATT and I had the CPU OCed from 4.0 to 4.5 @ 1.425v
