Asus M4A790XTD EVO Version 0602 BIOS
AMD Phenom II x2 Callisto - unlocked to a Phenom II x4 B45
2x1gb Crucial Ballistic DDR3 1333 Memory set at 6-6-6-20 (runs no different with the default 9-9-9-24)
EVGA 512meg 8600GT Low Power PCIE2 video card
WD 320gig SATA3 HDD
Hello,
I am not the smartest person on my block, or probably on your block either, but I do my own builds and I do spend some time reading and searching for what I need, when I have a problem.
The one I'm having now is just because my lack of understanding I'm sure, but I need to understand it and understand what I need to do with it.
Here's the problem: If I manually change the CPU voltage in the BIOS and reboot, the voltage I set shows up in the BOIS as the value I set, but in CPU-Z and in AOD, the voltage shows something totally different. The higher I go with the voltage in the BIOS, the lower it shows in CPU-Z and AOD.
Now, let me fill in the background as to why I am adjusting the voltage. I feel that is relevant to where I am going. I purchased a Phenom II x2 Callisto. I unlocked the cores, to see if I would get "2 free cores" (I couldn't afford the 4 core 945 CPU) and I ended up with a Phenom II X4 B45. All I did was to use these settings in the BIOS:Unleashing - Enabled, Active CPU Cores - 4 cores, Value all cores +4%.
By using those settings, I achieved a 4 core processor, but not without an issue. Let me say that when I first put this system together, I tested the memory using memtest86 before I did anything else. I then loaded XP and all the updates to XP including SP3. Then I installed Prime95 and other benchmark & testing programs. I tested with the processor at the stock 2 core settings and then I went to unlock the other cores. Since unlocking the other cores I have run prime95 for 12 hours straight in two modes "Small FFT's and Blend". It runs perfect, no errors. All the other benchmark programs I have run with no errors, no blue screens, no lock ups.
But........ I still get lockups in other programs. They are erratic. I might open internet explorer 10 times and work perfect or I might get locked up. I can open Outlook express a dozen times, but then I might get locked up. I can run games like Flight Simulator 9 for hours with no problems and try to leave the game and then lock up. The lock ups are always total, where I can only power off as a means to get out of the lock up. It does not matter if it's a microsoft program or an add-on program and it is not time based. It is sporradic and erratic, but it never locks up in any of the benchmark software. This is why I wanted to try upping the CPU core voltage and this is where I ran into this problem of upping the voltage in the BIOS only to find that after booting and loading into the OS, the voltage is Lower than it was before, even though it shows higher in the BIOS monitor screen. The only thing I can even reomtely think of would be that the CPU/VDDA voltage setting (if set manually), might help stop the voltage from lowering itself, but I don't think that will do it, since I understand setting it manually is only going to put a (high limit) on a setting that still automatically changes as needed?
I am not even thinking about overclocking yet. If I can't get it stable now, I won't try overclocking at all. What I just don't get is why it can run 12 hours of prime95 prefectly and then it can lock up opening a web page or outlook express. Or why I can play something like HAWX for an hour and lock up only when I exit the game.
Also about 1 out of 15 times, when I first power up, I get a BIOS statement that the CPU powered up unstable and I need to enter BOIS set up. I can enter the BOIS and then just exit without saving changes and it works fine again.
My personal feeling is that upping the voltage might help, but I don't seem to find a way to do that right now, so that's what I need, is an answer to the mysterious voltage setting.
I have read something that the CPU core voltage automatically lowers as the processor is pushed, more processing use, less voltage automatically, to save the cores? That is new to me, but does that have any bearing on why the voltage is lowering, when I manually try to raise it? If so, then how to stop that?
I know that, in the end, I may just have to go back to 2 cores, but I sure would like to try the voltages, to see if it becomes stable first.
Thanks in advance for your help here..... and your patience......
WD 320gig SATA3 HDD
Hello,
