- Oct 18, 2010
I'm a little confused on what I need to set for the most effective OC, so I turn to you guys. I've read some guides, but I'm still a little confused. Here's what I'm working with:
CPU: AMD Phenom II X3 740, 4 cores unlocked and appears to be stable.
RAM: 2x2GB DDR1600 Mushkin Redline 6-8-6-24 RAM
PSU: OCZ GamerXstream 750w
Question 1: When set to AUTO, the voltages seem to vary as needed? The higher I raise the multi, the higher the VCORE reading...kind of strange. Stock it's like 1.28, now it's 1.38 with the multi at 18. Is this normal? I was under the assumption that you had to manually set voltages.
Question 2: I would post a CPU-Z snapshot, but I don't have any editing software installed. I haven't done much, so here's what it says:
CPU Tab:
Core Voltage=1.38
Core speed= 3612, Multi=18.0, Bus Speed=200.7, HT Link=2006.7
Memory Tab:
NB Frequency=2608.7
DRAM Frequency=802.7, FSBRAM=1:4
Latencies: 6-8-6-24-40-2T
I have bumped up the multi, adjusted the NB Frequency, and manually set the RAM to these settings. That's it. I'm not sure if these particular settings are stable yet, as I just adjusted the multi even higher, but a lower multi 17 & 17.5 appear to be stable.
This is where I need some advice. What would you adjust?
CPU Tab:
Core Voltage=1.38
Memory Tab:
NB Frequency=2608.7
