- Sep 25, 2012
- New Zealand
Hi all,
Long time lurker, this is my first post, as you can see
I recently put together a new build, consisting of an AMD FX-8120, an Asus M5A78L and other bits and pieces, and I'm having a little trouble.
I asked some questions on the Asus forums:
(I fixed the APM throttling with AMDmsrTweaker as there is no APM option in the bios)
Basically the only response I got was "setting LLC to low will show differences in CPU-Z" - not helpful as I can't see voltages correctly in any software.
Can anyone here help me? I have the voltage set at the moment to 1.325 in the bios but its showing in all software (HWmonitor, CPU-Z etc) as 1.3375 no matter what I set - however if I change voltages using AMD Overdrive they show up correctly.
Question 2: Load line on these boards is weird, my previous motherboard gave me the options of Off, Low, Medium, High and extreme. This one on Auto is set to 48%, but setting it to either 0% or 100% gives me a massive boost in temperatures and dropped cores during p95 - does anyone that owns this or similar boards explain to me whats going on with it?
Thanks
Hi all, Questions: 1. The load line calibration option is a little bit confusing - the auto mode is set to 48% but I cannot for the life of me tell if 100% means highest setting or if 0% is. Any ideas? 2. I have very good cooling on the VRM's so I don't get the throttle down to 7x multiplier on my FX CPU, but I still get the throttle to 14x when under load. I cannot see a way to disable APM for the CPU on this Mobo's bios (Have tried the release from last week, still the same). I have found a work around using AOD to disable turbo core but that is tedious - any chance to get this option added to the BIOS? And 3, as much as I change the voltage for my CPU in the bios the voltage is still coming up as 1.3375 in CPU-Z - Can anyone else reproduce this? Thanks for your time.
Thanks
