justinmcla
- Sep 16, 2012
Hello everyone!
I've got a build here that simply will not display. It boots, as in, everything turns on with no warning LEDS.
The build:
NZXT Phantom 410 Case
ASUS M5A97 Motherboard
AMD FX-6100 Processor
WD 320GB Caviar Blue HDD
ASUS 24x DVD Drive
PNY GeForce 210
8GB Corsair Vengeance DDR3 RAM
ThermalTake 500W PSU
Okay, here's the rundown. Everything seems to be hooked up correctly, as far as I'm concerned. The mobo comes with several LEDs and built-in system checkers. I've run MemOK! and the RAM is working fine. I've run BIOS Flashback, so we're at the original BIOS settings. Both the 24-pin and 8-pin ATX power connectors are plugged in. The GFX card is receiving power. I've tried both VGA and HDMI connections with 2 monitors. Both have worked fine recently.
Any suggestions would be greatly appreciated.
The build:
ASUS 24x DVD Drive
PNY GeForce 210
