Hi Guys, I want to know My Asus m5a97(Amd fx 6100) is dead or not,it was perfectly fine for last five months,then it suddenly stop working, the cpu fan and graphics card fans are working but no video signal,first i thought it was psu issue because cooler master extreme 600 fans were not spinning even when i shorted the black an blue cable,so i replaced it, i got a new one from the vendor,i think the psu is ok now, because the fans are now spinning,but others are everything is same,no video signal, cpu and graphics card fans are spinning,the one thing i noticed is that the green LED is on but the dram memok LED is not liting,it was previously liting when the system was working,i dont know if it is the ram issue,the ram was prevously working it is corsair vengence 1600 4 gb,when i click on the dram memok button the red LED just blinks on and nothing happens,i tried different mem slots but nothing,i removed cmos battery and put it again,i resetted the jumper in motherboard as per the instruction manual,still nothing is happening, i want to know if it is bad memmory stick or bad motherboard or processor,and also i am not sure but there used to be a little beep sound when i switch on the system in its working past,now no beep sound even when i removed the memory stick from motherboard,
My Complete specs are
Asus m5a97
Amd fx 6100
Nvidia Gts 450
Cooler master extreme 600w
Corsair Vengence 1600 4Gb (single stick)
Asus m5a97
Amd fx 6100
Nvidia Gts 450
