Hi everyone.
I have a small problem with my new ASUS M5A97 PRO motherboard.
When system is loaded, the speed of CPU cooler is controlled by FanExpert software.
When i want to restart the computer, after the system reboots, speed of the CPU Cooler (rotation) decreases significantly , speed of the blades is so slow that you can successfully put something between them.
The fan comes on very low speed to the point where the system loads FanExpert into memory.
Theoretically, when you do not log into the system or remain at the stage of the BIOS welcome message - CPU temperature will increase.
With the increasing temperature, the cooling speed remains the same (slow).
I tried to test my strength placing hand on the CPU heatsink.
After several seconds i was not able to hold my hand on CPU heatsink - get very hot.
My bios version (latest).
My guess is that this situation should not take place, the CPU should be better cooled by motherboard.
Do you have any experience with these motherboards ?
Thanks in advence.
Thanks in advence.
