Hey guys so I finally decided to do a full custom water cooled build. After a massive amount of frustration tube bending, it was done....but refusing to boot. I did all the usual things ( reset the cmos with button then by battery, reinstalling bios via dedicated USB and button, reseat the CPU and ram, try without the gpu, unwire and re wire the whole thing, and more) there is no Video output via motherboard or gpu from any port. The motherboard is spitting out a 00 which accroding to the manual is "not used" and if I take out the ram it doesn't change at all leading me to think it could me a bad mobo and that it's not getting past post to the bios. But that doesn't seem right either. And usually any time I've had a bad mobo it's totally dead, where as This runs the fan, pump and the leds on the ram and mobo. Any help would be much appreciated.
Pc part picker list (some minor things changed)
https://pcpartpicker.com/list/dzBVVY
