So I have a 6700k, Asus extreme, and gskill trident Z memory. finally got my overclock stable at 1.42 vcore @ 4.7ghz. Ran Aida64 for 3 hour stable with 16gb ddr4 @ 3200mhz.
I then OC the memory (like I have many times) to 3600 MHz, changed the voltage to 1.38, and sa voltage to 1.250 as well as the vccio. It booted fine, rand benchmarks and the Cpu failed the same benchmark I passed earlier. The timing on the memory was 16-18-18-38 which is good for 3200/3333. However I set it to 17-19-19-39 and then it wouldn't post!
I don't hear any beeps. I get code 35. It shows the red led for Cpu and then 2 yellow for the ram and it just sits there.
I tried removing one stick, I have other memory here and tried that as well, no good.
I then reset the bios with clear cmos and removed the battery. I tried hitting the "memory ok" button and no good.
I tried the safe boot button, no good. I even drive selecting bios_2 by pressing the button on the bottom of the board, it just sits at QCode 00. Nothing happens.
How can I get this memory timing reset so I can boot up?
Thanks!
Edit: I do have a PC speaker and when I remove all ram, I get short beeps. 1....2.3.4. So I know that the Cpu and board are working.
Thanks!
