He can't get in the bios Joe board is most likely dead kill two OCF overclocking memory this platform is crazy.I just got a eeprom programmer thinking I borked the bios re flashed the chips and no go
@ OP do what Johan said and let the board set for a day or two
3x or 2x errors are related to memory. If it can't boot then you can simply hold power button for 4+ seconds, then turn it on and keep holding power for 4+ seconds. Then usually board sets BIOS defaults and throws an info that it couldn't boot ... and you can enter BIOS to correct settings. It's something like clearing CMOS but you don't have to set everything in BIOS again.
So when you get 00 error and reseating CPU or reflashing BIOS won't help then it's probably time for RMA.
This might be worth mentioning but the OC panel that comes with the board is in my 5.25" drive bay and still shows CPU temps, as well as CPU VSA (voltage?)? Not sure if this means anything.
