I have been working on overclocking my computer. It is an ASUS M4A785-M, a PhII 925 x4 2.8GHz 95 watt, with a corsair H50.
I have a few questions about some of my bios options and such. I underclocked my cpu and memory (isolating the NB/HT) and started turning up my reference clock to see how high my HT Link/NB Freq can remain stable. I got it to run stable for an hour of Prime95 at 263MHz with x10 multi'sat stock voltage. Turning up the HTT over voltage from 1.2 to 1.245, I got 265MHz to run stable for 2 hrs of Prime95 blend. Does this mean that when I am overclocking everything together that I won't have to worry about turning down the HT multi until I break the 263/265 barrier?
I haven't been able to find much at all about VDDNB voltage. It is an option in my bios. I'm not sure what it is by default, as it says it varies by CPU, but I can set it anywhere between .9 to 1.55 volts in .00625 increments. Also what do you recommend I do with this to improve my OC.
What do you guys think about Loadline Calibration? I have left mine on auto, which puts it at 53%. I have read that you should probably turn this off as you start getting to the max voltage of your CPU as it causes voltage spikes.
Should I leave CPU prefetching enabled?
I have heard that Advanced Clock Calibration is for unlocking cores, but since I am already running a Quad core is there any benefit to enabling this?
Sorry this is so long. I just wanted to try to get as good an OC as possible (me and everybody else, haha) and I didn't know enough about some of these other options in my bios. I had my reference clock run stable for 2 hrs at 265MHz (1.5v) doing small FFT's with my HT and RAM underclocked (CPU isolated). I haven't been able to get 270 to not BSOD though.
Thanks for all your help.
