ASUS P8P67 LE VS. P8P67
h055
What are the major differences between these two boards?
So far, it looks like the LE doesnt have "DIGI+ VRM", and there are some subtle differences with the PCI Express 2.0 x16 slots (possibly SLI support?)
The second board isnt in stock and I just want to put my 2600k to work. I am only using one GPU. Will I be okay with getting the LE board?
Did you see this legit reviews article:
http://www.legitreviews.com/article/1500/1/
So the big difference is the DIGI + VRM which sounds like it would be helpful benchmarking while in widows, but once you get your voltage set then I dont see it's use. Not to mention, anytime you have instability issues the computer usually BSOD or freezes, so a reboot is required none-the-less. Am I far off on this technology?
