Memtest86+ takes longer to run than MemTest HCI that runs in windows, there both good testing. Give MemTest HCI a try.wingman is that like memtest86 that runs in Windows? Cool!
Nothing has crashed yet. I do have AISuite installed but use corsair link to monitor my temps and to adjust my fan profiles. It seams to be the most accurate in this department.
Personally I would uninstall AISuite and then remove it completely with help from this link https://rog.asus.com/forum/showthread.php?95038-AI-Suite-3-cleaner
If you're not using it then it really is better if you remove it. It will always run in the background if you don't and as I said could very well have been partially reponsible for the blue screen that you had
Yea it was set at 1.27v @5ghz and the avx I think was the name of it was set at 1 and I do believe because of the avx instructions it throttled back to 4.9. It has been stable at 5ghz during gameplay with anthem.
- run AIDA64 FPU/CPU or Prime95 small FFT for ~1h+ to test CPU max temps and stability under full load
- run AIDA64 memory/cache or Prime95 blend for ~1h+ to test memory and IMC stability
- run 3D tests and mixed load tests to check general stability and behavior in typical tasks (can be realbench too)
During daily work CPU won't heat up as much as in stability tests. It can still show instability while playing games etc.
Have you followed these guidelines for stress testing? Will help you determine the cause of instability and thus which voltage to adjust. Are you running your memory at XMP?
