I'm new to computer building and overclocking so I started out with some older components so that I wouldn't be breaking anyhing expensive if I broke something. My build went good ... everything started right away, temperatures were good, all RAM and USB work, etc.
Build:
Asus P8Z68-V lx (newest BIOS 4105)
i5 2500k
Team Xtreem 2400 DDR3 ram
Noctua NHu14s
750W powersupply
RX 480
120GB SSD, 1 TB HD
With default BIOS everything runs without issue. The second I change something the system fails to boot to the BIOS. Asus optimal setting fails to load, any manual changes to voltage and multiplies - fails, turn on TPU switch - fails, enable XMP - fails, Asus auto tuner from windows - fails. The only thing that I can good from is default settings.
The board was used when I got it so maybe that could be the issue? I assume that if defaults works I should be able to make minimal changes and still have it run but this is not the case. I want to make sure I am not missing something before I give up trying to OC on the board.
Build:
i5 2500k
Noctua NHu14s
750W powersupply
RX 480
120GB SSD, 1 TB HD
