Code:
Mobo: Asus P8Z68-V PRO Z68 Socket 1155 8 Channel HD Audio ATX Motherboard
CPU: Intel Core i5 2500K 3.3GHz Socket 1155 6MB Cache Retail Boxed Processor
HSF: Arctic Cooling Freezer 7 Pro rev 2 Socket 775, 1156, 1155, 1366, AM2, AM3 Heatpipe CPU Cooler
GPU: Asus GTX 560Ti DirectCU II 1GB GDDR5 Dual DVI Mini HDMI PCI-E Graphics Card
HDD: WD 2TB Caviar Green Internal Hard Drive
PSU: Coolermaster GX 750W PSU
RAM: G-Skill 8GB (2x4GB) DDR3 1600Mhz RipjawsX Memory Kit CL9 (9-9-9-24) 1.5V
Case: Coolermaster Elite 330 Black Mid Tower Case
OS: Microsoft Windows 7 Prof 64-bit
Hi,
I'm using Asus P8Z68-V PRO Z68 and I'm having an issue with CHA_Fan1. My CPU_Fan and CHA_Fan2 are looking good. But CHA_Fan1 seems to be stuck at just over 800 RPM's.
CHA_Fan1 is a 4 pin plug and I've connected a 3 pin plug to it. I know the fan can go faster than 800 as it did so when I had it plugged in to the 3 pin CHA_Fan2 connection. I attached a front case fan and it would only stretch to CHA_Fan2 so had to move the back case fan to the 4 pin CHA_Fan1.
Is there anything I can change in the bios to increase the CHA_Fan1 RPM's or will I have to use the 3 pin to molex connector to the psu so it maxes out?
