- Nov 26, 2013
Hi guys, I just wanted some advice on SATA
Basically my last pc only had SATA 2 and everything was plugged into these ports
This motherboard has 2 SATA 6Gb/s ports, 4 SATA 3Gb/s Ports and another 2 6Gb/s ports with caching
Now im reading the manual and Im reading about ACHI mode RAID modes etc
In the past I only used IDE mode so I wanted to double check before I hooked these up.
Im going to be using 1 SDD for Windows and programs, 1 SDD for games and 1 SATA III drive for storage.
Here are links to my drives, they both say they can support up to SATA 6Gb/s
http://www.amazon.co.uk/gp/product/B007R67FTY/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
http://www.amazon.co.uk/gp/product/B00D0240M4/ref=oh_details_o02_s01_i00?ie=UTF8&psc=1
So I was thinking to plug the 2 SSDs into the SATA 6.0 (normal)
Plug the storage into 6.0 (one with caching because the maual say only use these for data drives)
Then use a SATA 3.0 for my optical drive.
I just wanted to check if this was a correct setup?
Now the maual says all these ports are set to ACHI mode by defult. Also its saying when SATA mode is set to RAID you have to load IRST driver at WIndows 7 installation.
No idea what this means, but it probably dont even apply to me.
Please let me know if this setup will work guys...Thanks
