Hello all! I recently built my first desktop PC in YEEAAARS.. Specs below.. I was wondering if anyone here has this mb and if they have any tips / tricks / insight etc to share. One of the things that has puzzled me is that in the bios, i have no idea where my M.2 drive information is found? I had to install windows on my HDD... install the samsung drivers for the m.2 drive... then i was able to use the disk management utility to format and install windows on it. Yet, i still can't find any m.2 info in the bios?? Go ahead and consider me a newb here.. so let me know if i'm being dumb please!
More dumb questions.. On the specs of the V Edition 10 for RAM it says "8 x DIMM, Max. 128GB, DDR4 3333(O.C.)/3300(O.C.)/3200(O.C.)/3000(O.C.)/2800(O.C.)/2666(O.C.)/2400(O.C.)/2133(O.C.) MHz Non-ECC, Un-buffered Memory "..
Can someone help me understand what all the numbers are and why they list so many? Is 3333 the max mhz of ram you can use and they are just being specific when they show you lower mhz ratings it also accepts?
Secondly, i bought the GSkill ram at 3200mhz after looking at the mother board specs.. but i see my processor supports 2400.. does this mean i'm limited to use the ram downclocked at 2400? Potentially slightly higher if it's overclocked?
Has anyone used the software for auto-overclocking the CPU that comes with the motherboard? Is it better to tweak / overclock manually?
Sorry for all the questions!! Thanks for any help!
Asus Rampage V Edition 10
Intel i7 6850k
Thermaltake Water 3.0 Riing RGB 360 Edition CPU Cooler
G.SKILL TridentZ Series 32GB 3200
SAMSUNG 950 PRO M.2 2280 256GB
WD Black 5TB HDD
EVGA GTX 1080 FTW GPU
EVGA G3 SuperNova 1000 PSU
Intel i7 6850k
WD Black 5TB HDD
