I am just curious do I have to use the top pcie slot or can I use a lower slot. Reason I ask is bc the water cooler radiator is in the way of the ports on the card if in the top most slot. I read the 4slot down was also 16x I believe.
Thanks in advance.
4 x PCIe 3.0/2.0 x16 (x16, x16/x16, x16/x8/x8 or x16/x8/x8/x8 mode with 40-LANE CPU; x16, x16/x8, x8/x8/x8 mode with 28-LANE CPU) *2
2. The PCIE_X8_4 slot shares bandwidth with M.2 x 4.
40-LANE CPU: The PCIeX8_4 slot can only be used in x4 mode or lower when used simultaneously with the M.2 connector. If x8 mode is used, the two connectors will be mutually exclusive.
28-LANE CPU: The PCIE_X8_4 slot will be disabled and the M.2 connector will always be enabled.
That is the last x16 slot I believe (what you have circled). The bottom one is max x8 and I think fed from the chipset. See BTD's post for more info..
The difference in performance is like 1% from PCIe 3.0 x16 to x8. It isn't a big deal.
