- Jul 12, 2011
- MN, USA
Hello.
I'm planning to get a new motherboard sometime soon.
I am looking at either the CHV or the Sabertooth as you can see.
EDIT- I'm guessing the reason people aren't answering is because of how long/bulky this is, so.
Question: should I get sabertooth or Crosshair V Formula?
It looks like they are pretty similar.
Are either of them better for overclocking AM3 CPUs? (1090T).
I'll want to be able to overclock a thuban as high as I can (without killing it) for benches. Also, can you get a better stable 24/7 overclock with one of them?
One thing I noticed is that the CHV has an 8-pin AND 4 pin power connector. The Sabertooth only has an 8-pin.
Also, the highest memory speed the Sabertooth supports is 1866Mhz. The CHV goes up to 2133Mhz.
A friend will sell this ram to me for $35:
http://www.newegg.com/Product/Product.aspx?item=N82E16820231460
(G.Skill Sniper 1866).
The CHV does not have 1866Mhz as one of the memory speeds. Would that be a problem?
I'll eventually be running Crossfire, but that won't be a problem on either of them.
Sorry for the long post, just want to see what you guys think of each of them.
Also one more question- does anyone know what socket Piledriver will be? I've seen both FM2 and AM3+, so i'm unsure. I'll probably skip BD entirely unless a revision comes out that is AM3+.
-notJUSTguitar
EDIT: forgot to mention that I would problem buy open-box on newegg unless people strongly oppose that, as I don't have that much to spend on comp stuff right now
Open box Sabertooth: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131736R
Open box CHV: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131735R
-notJUSTguitar
