- Aug 16, 2009
A list of the 12 Asus X570 Motherboard from Asus at Computex
https://www.tomshardware.com/news/asus-amd-x570-motherboards,39457.html
That is correct.It's because of ~10W higher chipset power and that most higher motherboards have integrated/connected M.2 heatsinks to the chipset heatsink.
I think part of the chipsets power use is due to pcie 4...something that doesn't go away. Perhaps on the extreme non overclocking budget boards they go pcie 3.0?
Sure? But why? Why would I add more complexity and cost to my board when a fan will do teh job cheaper and with less hassle? Really, the fan should be monitoring the PCH temps and come on when needed. That is easier to implement than additional switches and such I would imagine.Assumption: heat production is primarily affected by bandwidth usage. CPU connection x4 3.0 is ok for passive cooling, x4 4.0 is not. Could they offer a dynamic speed switching link between 3.0 and 4.0, or equivalently lane count depending on thermals? So similar to CPU/GPU thermal throttling. Short bursts of high performance are ok, but if sustained fall back to lower operating state to limit power output and thermals. Even if limited to 3.0 equivalent back to CPU it would still be upgrade over 400 from supporting newer standards on connected devices.
Though it is nice to see some smaller quality form factor boards coming available.
People are not going to buy smoking fast PCIE 4.0 x4 drives to have them be throttled by the board during sustained operations.
I guess that someone didn't like that ASRock listed X570 Taichi and Phantom Gaming X on their product website. Yesterday both were there with additional banner, today are not visible. Both seem to be on the same PCB. Just to add, official memory support for these 2 ASRock boards is DDR4-4400+. QVL was not available and I couldn't check on what memory it was tested.
New motherboards will probably hit the stores before processors but X570 won't support 1000 series Ryzen.
