- Feb 28, 2011
Hi guys,
I have an opportunity to pick up either of these boards for my new build for a 15% discount. I will only be doing moderate overclocking via UEFI to 4.6GHz without fiddling with voltages, and will only be running my memory in XMP. I also will NOT be using bluetooth or wifi and I already have my own soundcard.
I value reliability and stock performance more than anything else. But overclocking stability does come in a close third. My impression of the Sabertooth is that it is potentially more reliable/ruggedly built than the Formula (there's a reason Asus slapped a 5-yr warranty on the former and only a 3-yr on the latter), while the Formula is also quality-made and has greater potential for overclocking (but not so useful for me).
Basically I was leaning towards the Sabertooth because of its five year warranty plus that sick TUF aromor, but I was also told that it didn't overclock well? But since I only do moderate overclocking at stock voltages, I think the Sabertooth would serve me better, no?
Lastly, I'm targeting these two boards specifically for their armor casing, which looks sick!
My spec:
i7-4770K
Noctua NH-D14
G.Skill Ripjaws X 16GB (2X8)
Thanks!
My spec:
i7-4770K
Noctua NH-D14
Thanks!
