For some reason HWMonitor is not showing the most important temp, the "core" or "package" temp so all you have to go on is the CPUTIN or the socket temp. One thing is not clear to me from your pic of HWMonitor and that is if it was taken while the CPU was still being fully loaded while running Prime95 or if you had stopped the stress test before taking the screen shot. If your CPUTIN temp (current) stays around 74c (i.e., approximately matches the max) under load then you have a temp problem. If under full load the current temp is much lower then I would consider the max reading just an aberration and would not worry about it.
Please give more info about your hardware. Motherboard make and mode? Are you cooling the processor with the stock heat sink or some aftermarket product and if so, what is the make and model of the cooler? Tell us about your case. How many case fans and where are they located? How large are the fans? How many of the fans are intake and how many are exhaust? Good case ventilation is critical to keeping processor temps down.
One more question. By some chance do you have core unlocking enabled in bios? That generally interferes with core temp reporting.
