- Mar 14, 2006
Hey everyone. I have an Asus A7N8X Deluxe motherboard, and I had my old Athlon XP 2500+ die on me and the only thing I could find at any store to replace it with was a 2800+ mobile XP. I've read lots of forums where people have said that mobile CPUs work fine with this board, but I can't get it to work properly. I set the external freq. and clock multiplier to 133 and 16, as AMD said I should, but the clock speed in the POST and in Windows is showing up as around 1ghz instead of around 2ghz, where it should be. I've changed the frequency and multiplier settings around quite a bit and every combination seems to result in half the clock speed that it should be.
So next, I thought maybe it was just reporting half the speed but running at double like it should be, so I did some benchmarking with PassMark Performance Test, and my other computer with a Sempron 2400+ scored considerably higher than the 2800+ so there definitely is something wrong.
The other issue is with the temperature - the hardware monitor in the BIOS is reporting around 70 celsius, but the PC Probe software temp. monitor is reporting around 42 (at idle). Thus I'm somewhat worried about turning the freq. and multiplier up too much because even though it seems to be massively underclocked right now the temperature is still being reported as relatively high. However I'm not even sure if that's accurate at all because the heatsink barely feels warm to the touch.
Can anyone help me out? Thanks!
