- May 6, 2011
Anyone feel like helping out my issue? : )
I know the deal with increasing voltage for stability at higher clocks, and if it hits around 95c that's really bad. So with that prelude....
As for the main thread; Post-patch, my BF3 is crashing at all clocks, stock and OC, so I'm with you guys there (it was pretty rare before the patch, after the patch it was like every other game (>.<). My friend has RealTek drivers too though, and he's fine.
As for my issue, Unfortunately, since my mobo and CPU are messed up I can't do any tests for you guys to see if something works..so if you have ideas as to what the issue is, when i get a new Mobo and CPU i can check and see if it works.
However, that's not my question, what my problem is, is that I can hit 960mhz at 1.25 V, give or take. My temps don't go above 70c, and when I raise the core mhz, it'll hang in whatever tests I run. I increase the voltages, even up to 1.29V, and even that doesn't solve the issue. My temps are perfectly normal, even low, and yet I can't raise the core/voltages without it hanging in tests. Any idea as to what the problem is?
