Deanzo said:
I know your ram is 1000mhz, But I havent seen anyone get this board to run ram at that speed even if the ram is up to it.
Hi all from XtremeC, just thought I would add to this post as it might be somthing AW9D max owners would be interested in.
I have tested 4 kits on this chipset and board, Kingston 2 gig 1000mhz with 5,5,5,15, Crucial 2 gig 1000mhz with 5,5,5,15, Corsair Dominators 2 gig 1066mhz with 5,5,5,15 and Super Talent 2 gig 1000mhz with 4,5,4,12.
Basically the Supertalent ran at 1002 at them timings with 2.1 volts, the only kit to go past 1000, this was followed up by the dominators that hit 980 at 4,3,4,10 timings with 2.3 volts. then the Crucial at 960 at 4,3,4,10 with 2.3, and the kingston hit 980 but only at 5,5,5,15 timings.
To achieve the memory speeds with the super talent i took a stock 6600 set voltage to 3.25, set the strap to 1066 the MCH to 1.8 and set the ram to 2.1 and 800mhz. then just raised the FSB to 346 or there abouts (sorry at work cant check right now) this booted straight away with no problem and is Othros stable after 48 hours.
Sorry to butt into your thread, i was going to post this on Abit forums but it was down hope this helps you out a bit
